This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Ensure the power cable is securely fitted to a wall output if you can't get your Panasonic LCD TV to power up. Try testing the wall outlet with another appliance to make sure there is not electrical fault with the outlet itself. If there is still no power, a blown fuse may need replacing.
Switch off the color correction option if you are using HDMI cables and the displayed image has unnatural colors. For instance, if a picture area that should be red is blue or green, then the color correction option may be the issue. Press OK on your remote control. Now access the Other Adjust option and scroll down to the Color Correction option. You can now turn the setting off, which should restore normal image quality.
Press the Mute button if you can't get your Panasonic LCD television to produce sound. This may have been pressed in error, cutting off the sound. Check the volume settings on any other devices, such as a games console or DVD player, that are connected to your LCD TV. If the volume is set to low on such a device, it can limit the sound output on your TV.
Check that the air vents at the lower rear of your Panasonic LCD TV are free of dirt and debris. Dirt can accumulate in these areas, causing the cooling function to under-perform. Panasonic LCD sets come with built-in safety features that shut off the power if your set becomes too hot. Clean the air vents with a damp, rather than wet cloth. Dust and vacuum the room regularly to prevent the problem from recurring.
