Microwave Ovens Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there, I have a LG model: LMV1640DW1 microwave oven. Everything seems to be ok, but does not heat my food. The microwave is fairly new (feb 2008)
michael
Level 2:
  • Expert 155 Answers
  • Posted on Apr 19, 2011
michael
Expert
Level 2:
Answers
155
Questions
5
Helped
48529
Points
371
Possibly high voltage fuse or diode.If it is an inverter model may be circuit board problem.Not advisable to try and fix yourself very high voltage build up could still be present, contact your local repairer.
My microwave wont heat food. Everything else works. Just no power.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
My lg microwave is not heating food everything seems to be working fine
Basic Microwave Oven Troubleshooting Tips
heatman101
[00000000000
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
heatman101
=0=0=0=0=0=0=0=0=0
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r
3helpful
Everything seems to be working but it doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
6helpful
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
