Computers & Internet Logo
Posted on Apr 19, 2011
My laptop stopped picking up wifi after a much needed modification. I have a 3 year old hp pavilion dv9000. the hinges broke so I decided to remove the monitor of the laptop and hook it up to a desktop monitor. everything seemed okay when I turned it on but after my programs loases the computer wouldn't connect to my home router. is it because I disconnected my monitor? and is there a way to fix it?
LaptopDoctor
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Apr 09, 2012
LaptopDoctor
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
217044
Points
55
That is because the WI-FI antenna wires were on the LCD panel behind the glass.
Currently your laptop base has no signal. The only solution is that you may pick up a signal with the base alone, if it is near the wireless router about 20' (3 meters).
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Apr 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
Helped
5852
Points
87
No its not due to u r monitor change you reformat u r laptop and then try it
3helpful
4answers
How long is the battery on a HP Pavilion dv9000 supposed to last?
Laptop batteries will usually last from 1.5 to 5 hours, depending upon the demand, the battery and the use. Sound burns up a lot of juice as does the DVD player so if you're watching movies or playing games an hour is about right. You can purchase a better HP PAVILION DV9000 Battery with 12 cell , it will work longger.
detail: http://www.battery-center.net/hp-pavilion-dv9000-battery.html
tip
HP Pavilion dv9000 battery tips Your new HP Pavilion dv9000 laptop battery comes...
DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Chemistry : Li-ion
Voltage : 14.8V
Capacity : 4400mAh
Corlor : Black
Original Price: US $85.63
Special Price: US $65.63
warranty.jpg * 1.One year warranty, 30 days Money Back.
* 2.Brand new, 100% Q.C. of every battery.
* 3. Highest quality Japanese battery cells.
* 4. Guaranteed to meet original specifications.
* 5. 100% secure and safe.
  • Shipping: Our laptop batteries are shipped by USPS.
    The battery have a good compatibility with many original laptop batteries for many laptops, even diffenent brands.
  • Descriptions of Hp DV9000 DV9700 DV9600 HSTNN-IB33 Battery 1. 100% new high quality Replacement DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Compatible Li-ion Batteries.
    2. This Hp DV9000 DV9700 DV9600 HSTNN-IB33 battery can be used for the other models and battery part No.
    3. 30-Day Money Back,1 Year Extended Warranty for Hp DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery.
    4. Great After-sales Service Department for laptop battery, fast respond to your request!
    5. Fast delivery if you order the Hp laptop battery.
    6. Need any assistance on DV9000 DV9700 DV9600 HSTNN-IB33 Laptop Battery, please feel free to email us!
  • on Jan 27, 2010 • Computers & Internet
    1helpful
    2answers
    HP Pavilion dv9000 screen lock jamming on the hinge. Is there a key for the nominal padock on the hinge?
    I just started getting this problem myself. I'll let you know if I find a solution. For the time being, I'm pinching the joint with my fingers as hard as I can when I open or close it.
    3answers
    Replace hinge on HP Pavilion dv9000 labtop
    Check out this WEB site on how to replace a hinge on a laptop. It may not be exactly the same model as your laptop but the principles are the same, Click on this link :-
    http://www.insidemylaptop.com/
    4answers
    I have a 3 year old hp pavilion dv9000. For 3
    Quite often this is caused by someone changing the display type. There should be a function key control that allows you to view just your lcd display, an external display, or both. Try and change that setting and see if it will resolve your issue.
    4helpful
    2answers
    I have a hp pavilion dv9000. and i need the screw for it.
    Check out page 86 for the display schematics. Page 120 outlines the dis-assembly. Page 154 actually describes the screws of which you speak. You may be able to purchase them locally.
    http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
    My hp pavillion dv9000's hinge broke. But I was able to use it after. Then I tried to close it..and it just shut off and it will not come on. I want to know what I can do to fi it
    HP *had* issued service alert 08112101 which covers the left display hinge failure.
    HP Notebook Left Display Hinge Program
    HP Pavilion Notebook
    model series affected: dv9000, dv9100, dv9200, dv9400.
    This program recently ended on May 31, 2009, but HP may still allow for a grace period.
    Otherwise, you'll need the following:
    Display panel back panel enclosure (single lamp) 432957-001
    Display hinge kit (single lamp) 432963-001
    LCD bezel w/ webcam (single lamp) 432955-001
    Trained pro's should be able to do this in about 20mins, there is partial lower case disassembly and complete LCD housing dis/re-assembly.
    -Sy
    2helpful
    Tightening HP Pavilion DV9000 17'' LCD Hinges
    you may find the hinges parts from eBay which is cheaper price:
    http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
    how to replace your laptop hinges:
    1) take out the screws at back of laptop under the hinges base
    2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
    3) there are two cables connect between LCD lid and laptop base
    you do not need disconnect those canbles. just careful them
    4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
    5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
    6) put back all screws step by step.
    hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
    Hp laptop pavilion acts like it's booting up but screen is blank?
    May I ask what model it is?
    The dv9000 model if you havent been told had some that had bad motherboards and that sounds like what mine problem was.
    If its a dv9000 then you may want to talk to a HP agent about that.
    1helpful
    2answers
    HP Pavillion Dv 9000 stopped recognizing wireless networks.
    make sure ya have a VISTA compatible Driver for ya wifi ... go to manufactures web site and DL latest one for VISTA..
    Remove and reinstall most up to date driver... then use ya connection program to set it up.
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
