Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
SOURCE: my ps3 keeps freezing during the middle of a game,
Make sue you have the latest update on your ps3
SOURCE: PS3 error 80010017 or game will start up but finish loading
Easy fix :)
Go into Account Management ([Friends] [Account Management]), de-activated and activated again.
If this does not work, then your HDD is corrupt.
SOURCE: MY PS3 KEEPS FREEZING DURING A GAME.
hold ps button down wen turning on and a playsation bios screen will come up click on systm resart mite work
SOURCE: freeze during gamplay
PS3 is one of the most amazing gaming device but like other Competitor.
gaming devices (Xbox and Wii) It also has some problems like Freezing
up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up..
SOURCE: ps3 keeps freezing on games only
my playstation 3 plays cd's, dvd's, but will freeze up on games after 3-4 minutes.
