Bunn NHB Coffee Maker Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Bunn coffee maker. I'm not sure of the model number but it is rather new being that I purchased it in August 2010 and began using it in December 2010. To describe it, the top has a lid that swings around to the side to put water into the reservoir and will not let water pass through until you swing the water back to the closed position. This morning I poured water into the reservoir and brought the lid back to the closed position however water will not come out. I tried adding more water but this did not work either. PLEASE HELP!!!!
mwarej123
Level 3:
  • Master 454 Answers
  • Posted on Apr 19, 2011
mwarej123
Master
Level 3:
Answers
454
Questions
Helped
180277
Points
1400
Need temperature limit switch for garbage Bunn coffee maker.
Not sure your model name is correct and we always need numerical model names here. Bunn are such a well known name in coffee machines, I find it disappointing that they say ANY machine is not repairable. I found some Training Manuals and I found a 'Thermostat Limit Kit'.
https://www.google.com/search?q=bunn+grab+fast+brew++temperature+limit+switch
The search query would be
Bunn (numerical model number) temperature limit switch
Is there a current recall on Bunn model GRX-B?
Don't know about a recall, but the most common cause is a bad element.
Jan 22, 2014 • Bunn GRX-B
Leaking faucet
Can you advise the model number? Most Bunn machines use a faucetwith a rubber membrane inside which is difficult to repair. Its simpler for the owner to replace the faucet with a new Bunn item. If I know the model I may be able to give you the part number you need
I have a Bunn coffee maker. I have had it for a few years but not sure how long. Recently it started to leak water from the bottom and causes a huge mess. The model number on the bottom is GR10-W. Hope...
If you will call Customer Service with the date code and model, we do have a seal kit we can send out or offer you an out-of-warranty exchange. The number to call is 800-352-2866.
The heater in my Bunn Coffee Maker continues to heat. It got so hot this morning the top of the coffee maker began to expand
If you will get the model and date code located on the bottom of the brewer and call Customer Service we will be happy to help you. If your machine is still under warranty-3 years or less-we can replace it free of charge. If it is over 3 years old, we can offer you an exchange for a new machine at a reduced price.
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Bunn Cooffee Maker is not making full pots of coffee
I would ask if this machine has been moved lately- for cleaning or has anyone put anything new around the brewer? If someone has moved this brewer, they might have caused a kink in the line coming to the back of the brewer. this will restrict the water flow to the brewer. this will cause the brewer to brew only part pots of coffee.
1helpful
2answers
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
