Question about Kaz Sesame Street Elmo & Friends Humidifier - Blue
How do I clean this humidifer? I have the sesame street elmo and friends cool mist humidifier and I cannot find the manual for cleaning instructions. thank you
    Brigadier General:
  • 4,736 Answers
The outside you can clean with warm soapy water. The inside can be flushed with a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank and run the unit until the tank is almost empty. Pour out the remaining solution and fill the tank with more of the Bottled Distilled Water. Operate the unit for 30 minutes and the previous solution should have been flushed out by then. I would recommend using Bottled Distilled Water all the time rather than tap water. As tap water has a lot of minerals in it that can cause calcium scale and clog the unit.
Hope this helped you.
Posted on Apr 19, 2011
SOURCE:
Brand new. Why doesn't it work and won't mist?
if not working and is new, call your cust service for the humidifier and tell them, they will determined if u can fix or needs to be replaced, this is the only way
Humio Ultrasonic Cool Mist Humidifer Stylish Room Humidifier and Night...
Jan 05, 2016 | Humio Humidifier HU-1020 with Aroma...
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
I used to see mist coming out of the humidifer. Just set up for this year, changed the filter, etc. and there's no mist coming out. Is this ok?
No you probably have scale around the heater thus not heating the water warm eneough. The water trough is located in the bottom of the unit and it gets covered with scale you can sometimes crumble it off with your fingers. Sometimes you have to use a cleaner on them too. Me personally on mine I clean it with a flat blade. I have cleaned mine twice this year as I have hard water
Dec 13, 2010 | Vicks Cool Mist V3500 Humidifier
Kenmore HW305 Humidifier putting out hot steam...Is that normal?
this is a steam and misting type humidifier, the water tanks will not heat up, the heating element is internal to the unit, just make sure you clean it periodically and I would suggest having a fan asst to help move the humidification around the room, hope that helps
Jan 20, 2009 | Kenmore Humidifiers
My mother's Kenmore HW305 humidifier is putting out hot steam. Is that normal or is this a cool mist humidifier?
Yes it is doing what it is supposed to do, just remember to clean it regularly, it is both a fine mist and steam, I would recommend having an fan source close to it to keep the humidification moving in the home, hope that helps.
Jan 20, 2009 | Humidifiers
The humidifier has stopped producing mist
boogiecheck is right, the one pictured uses natural evaporation( no white dust) I just ordered one from abdistrsupport@gmail.com and mine works great. I own 3 total.
Dec 07, 2008 | Venta - Airwasher LW44 Humidifier
Kaz Sesame Street Elmo & Friends Humidifier - Blue Logo
241 people viewed this question
Top Kaz Humidifiers Experts
ray gallant
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
