There are several things to look for, but here are the first things to check:
(right click on Computer (or My Computer, or This PC) in your file explorer and choose properties to see your Workgroup or Homegroup information) in any case, both computers must be on the same network).
SOURCE: Dell laptop print spooler service is not running
go into control panel under administrative tools and go to spoiler and enable it
SOURCE: Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
SOURCE: On Dell Inspiron 1501, at college dorm, wireless internet drops
Hmmmm
If you can obtain an "802.11 N" wireless card, a USB type then you may have better luck maintaining your connection.
In the meantime, set your card to use "Only G", not "B" or "A".
This will keep your connection at the highest speed until you invest in a "N" adapter ($30).
Hope this helps!
Testimonial: "Thank you - hope it's easy as you make it sound!"
SOURCE: dell inspiron 1521 error code 2000-0146
Hi eodnd119,
That's not a good error code. That is telling you your hard drive is bad.
You likely have a drive where sectors are going bad - sometimes they may be readable, sometimes not. But it's just a matter of time before the drive fails completely.
Replace the hard drive.
Good Luck,
Mark
