C2652 Magenta Imaging Unit EEPROM access erro. you need to: 1. check if EErpom of Magenta Unit is not dirty. if it is, clean it. Else, replace the Unit image.
C - 2651 Cyan imaging unit EEPROM acces error C - 2652 Magenta imaging unit EEPROM acces error C - 2653 Yellow imaging unit EEPROM acces error C - 2654 Black imaging unit EEPROM acces error. Clean the connection between the imaging unit and the machine if dirty.Reinstall imaging unit or change imaging unit. Try reset: Turn OFF the copier. Press and keep pressed the Utility key and turn ON the copier. Keep pressed the Utility key when the Trouble resest message is displayed. Release the Utility key and touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
The extra side tray feed was way out of alignment. It must have been kicked or bumped and the motor was not lining up to the feed so the paper was not getting picked up. There are two metal anchors on either side of the tray, they were adjusted. The c351 had to be reset after the repair, like rebooting a computer.
