Question about Dell Dimension 2400 PC Desktop
Whenever the monitor is turned on, it displays for about 3 seconds and then goes black. what to do? It is only about 3 yrs old
  • Phil
    Phil Apr 18, 2011
    Need make and model of the monitor
    Scholar:
  • 86 Answers
One of three things is the most likely culprit.
1. Onboard video card is either disabled or bad.
2. Cable is bad
3. Monitor is bad.
You can check the last 2 relativly easily by hooking the monitor and cable up to another computer to see if they function. if they don't then first try swapping out the cable (i say this first because its cheaper) then swap out the monitor.
To see if the video card is bad try hooking up a different monitor to the system. If the new monitor is not displaying anything then you most likely will need to put a new video card in the machine.
Posted on Apr 18, 2011
SOURCE:
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
LG Flatron L1720P Loses Display
The backlight inverter board is defective or a high voltage cable going from the inverter output to the lamps is damaged or touching ground.
Feb 07, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
59 people viewed this question
Clive
Clive
Alun Cox
