Front right would most likely be the discharge pump. Here's a diagram:
Sounds like you could have a pump problem or a loose hose. First, go ahead and clean the drain pump filter (as per instructions in the Use & Care Manual). Screw it back in tightly to see if that resolves the issue.
If not, check this posting for how to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you don't get any error codes and all tests run correctly, open the front access panel and see if you can figure out where the leak is originating from (To remove the panel: undo three screws and lift from the bottom).
Please post back once you either have codes or have located the leak source...then we can troubleshoot more.
front load ge washer is leaking
