Ovens Logo
Posted on Apr 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Magic Chef gas oven. The broiler won't turn off. Ihad to shut off the gas and unplug it. Model 3568XVW. Where should I start?
Anonymous
Level 3:
President:
  • Master 1,430 Answers
  • Posted on Apr 18, 2011
Anonymous
Master
Level 3:
President:
Answers
1430
Questions
Helped
308140
Points
4820
This is usually caused by the main control. The relay for the broiler has likely melted into the on position. Here is a link that should help Replacing oven ERC
My problem is...the stove top is working fine, but the oven won't light. any suggestions to the reason why. the pilot still comes on but it's not releasing gas to start.
I recently had the same problem and it turned out to be the igniter. You will need to know your model number. I found mine in the bottom left side of the broiler section.
http://www.partselect.com/Entry.aspx
Replaced bad thermostat on Magic Chef model 9112xpb. Ignitor now glows orange but oven still won't start. Does gas valve on bottom of oven need to point up or sideways to start?
Gas shut off valve handles are perpendicular to the gasline when closed and parallel when opened. If you are referring to the appliance regulator behind the stove, the lever should face up or out, as opposed to sideways. This particular lever only shuts gas down to the oven and not the stovetop.
Let us know if you need more assistance.
Magic Chef oven does not work but all burners do
25 yr old oven...........so I bought a new one with a few blemishes for $200.
Magic chef model # 6498vtv broiler goes bang when it lites-- what do i adjust to prevent this? Gary
your not getting enough air to fuel ratio and you need to open the air vent just a quarter of a turn
How do I troubleshoot my Magic Chef electric built
Hi,look in the control console for the tech sheet or under the top of the unit.A good place to start.Hope this helped.
Nov 17, 2009 • Ovens
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 • Ovens
Build in Over Gas - Oven does not heat
I called a repairman it was the igniter.
2answers
Magic Chef range
Ignitor is very fragile and may have cracked.
Top Magic Chef Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
