SOURCE: Artemis/p3300 After reboot "Device start up failed..." and hard reset :(
DO NOT USE THE TOUCH SCREEN ....instead, use the LEFT soft key to select "continue" ....I guarantee it would work again hehehehe......BUCHOG here
SOURCE: My HTC p3300 battery not gettin charged. It works
its a battery issue u have to try changing the batt if t helps it might be the charger as well try charging from another source like usb charger from pc thru usb cable came with pda see it helps
SOURCE: hoe to connect htc p3300 via wifi
try start>settings>connections>wi-fi>configure wireless networks as per availability
SOURCE: how to connect htc p3300 mobile to pc
search google
microsoft active sync 4.5 download
first result is download page..
