Freezers Logo
A
Anonymous Posted on Apr 18, 2011
A year ago I was given a very large White Westinghouse Fridge-Freezer of unknown age. I can't see the model number as some of the information on the back has been damaged. It's an American-style product, with two tall compartments side by side rather than on top of one another. The freezer section has an ice maker and cold water dispenser... anyway the machine worked well for months, but now although the machine appears to be still running - lights, compressor etc, it's stopped getting really cold. The freezer side is just above freezing (Ice doesn't stay ice but it feels cold) and the fridge side is only just below ambient temp. The only thing I can see wrong is that at the back is a narrow plastic tube coming out of a joint near the top of the fridge: this had become detached, and it seems empty. I have put it back, but it's still empty. I am afraid the product may not be repairable but I need to be sure. What should I do?
Anonymous
Level 1:
Guru:
  • Contributor 683 Answers
  • Posted on Apr 18, 2011
Anonymous
Contributor
Level 1:
Guru:
Answers
683
Questions
Helped
136359
Points
21
Have you tried cleaning the condensor coils.
Freezer defrosted by itself and fridge is not as cold as usual
Try adjusting the Thermostat switch first (increase coolness). Stillyou have the same problem, take it for repairs.
I'm having things freeze in the fridge side not sure what to have the temp set at
Set the temp at 4 and then close the vents a little coming in from the freezer if you have any. If this doesn't work then your thermostat may need replaced. Also always for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
What is the separate Cubic Capacity of the Freezer and the Fridge of the Samsung Fridge Freezer SR-L36
that comes up as an amana freezer here is the page you can go to and find the information, there are 20 models with that listing so you will need more detailed information off of your metal tag that has the parts number and serial number when you look at the one you spoke of you will be able to pick which model it is.
Jan 16, 2010 • Freezers
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
9helpful
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Parts
jacoby apliance parts 1-800-698-1049 dan
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
