Master
- Posted on Apr 18, 2011
Re: Samsung ua46c8000 tv ir/sensor dose not work
Good day!
Please follow this procedure to find the exact problem.
- Check the battery of the remote.If your battery is 1.5vdc x2,the reading should be 1.5vdc x2 also! or 1.4vdc,tolerance to response the remote.Replace the battery if it is below on the tolerance voltage.
- Check the IR sensor using a digital camera or cell phone camera.
- Place the camera in the front of IR sensor then push any of the button to activate the remote.If your IR sensor flashes on the camera it means you IR sensor is good if not flashes on the camera replace it.
I hope this information will be helpful.Thank you very much.
