Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
Shield: Connect to pin 1 of the microphone jack on the radio
White: Connect to pin 2 of the microphone jack on the radio
Red: Connect to pin 3 of the microphone jack on the radio
Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
Is the d104 a amplified tug8 (4 wire) or tug9 (6 wire) or is it a non amplified mic? Found this...hope it helps.......... Astatic (4 wire) 1- White 2- Shield 3- Black 4- Red
Astatic (6 wire) 1- White 2- Shield 3- Blue 4- Red Black- N/C Yellow- N/C
You've probably already found the answer to this question but doing a search for D104 wiring to ICOM will show you what you need. If the connector is the 8 pin circular one, then the PTT and MIC connections are the same for all ICOM radios.
This works for any mic. dont worry about color codes. look at the switches.. there will be a common on both poles of the d104.. those need to be tied together to grnd. pin 1 on mic . the others d104 on n/c side is your rx. pin 4... the n/o one will be your tx pin 3 the other n/o will be audio and will have a wire from the mic element also on that pole of the switch. pin 2..
OPEN IT UP THE SHORT MAY BE WERE THE 2 POWER WIRES COME TOGETHER AS THEY ENTER THE RADIO THIS HAPPENS ALOT OR DESOLDER ONE OF THE WIRES OFF THE CIRCUIT BOARD AND CHECK FOR A SHORT ON THE WIRES AGAIN THIS WILL TELL YOU ALOT IF IT IS THE WIRES OR IF IT IS ON THE CIRCUIT BOARD GOOD LUCK
