Hi there
this is called wet sumping !
sounds like you may need to replace the fuel needle valve and seat if its replaceable
if the float is plastic the fuel level may not adjustable
your worst case cenario is replacing the carb ? if you cannot get replacement parts
but try
http://www.ereplacementparts.com/honda-parts-c-37657.html
type in your honda model off your engine block or plate
then go to the correct page for fuel system then order parts as needed
give it a try
cheers hope this helps pauly46
