Question about Dremel Variable - Speed Multipro Rotary Tool 395
PLASTIC GEAR INSIDE THAT CONNECTS SHAFT TO MOTER SHAFT DISINTEGRATED
  • 2,176 Answers
I found a coupling part at ereplacementparts.com and the part number is 2615294309, but I would recommend calling Dremel direct at 1-800-437-3635 to ensure this is the right one. They made a change on this coupling. Let me know if you need more assistance.
Posted on Apr 18, 2011
SOURCE:
Makita DHP481 Drill will not change into low gear (1) and is locked in high (2). What could be the problem?
Gearshaft problem with the gear house
a border of small ridges which must be locked in first gear, the gear shaft that runs now through if engine is running and switch from 2 to 1 gear , the locking teeth becomes broken in the housing
126410-4 is the ordering but no separate parts to get "Do not run the machine if you switch from 2 to 1 or 1 to 2 there are 2 special springs inside the switch slide inside to switch the machine having to rotate because inside the metal (aluminium gear shaft ) that Vertaling voor is scherp getand en maakt de plastic borging kapotVertaal in plaats daarvan naar is scherp getand en maalt de plastic borging kapot is sharp serrated and makes the plastic retainer broken.
Jun 19, 2016 | Makita Drills
The chain sprocket does not move but the moter runs
I think you need to replace the drive gear. look inside the main housing. if you see white plastic shavings that would confirm the gears are stripped.
kits are available for under $25.00. don't buy the one with just the gears, get the new shaft sprocket etc.
Not a difficult repair. However, be sure to follow the instructions carefully. the position of the chain & sprocket when you put it back together do matter.
Good Luck
Steve
Mar 02, 2015 | Sears Craftsman LiftMaster Chamberlain...
Speedometer quit working after transmission work and trans won't **** on 1999 Chevy silverado 4x4 5.3l
Most transmissions have a plastic gear mounted on the uotput shaft that connects to a gear on the end of the speedo cable or electronic sender unit for the speedo. This gear is normally driven by a steel ball embedded in the shaft and the gear has a slot that makes the ball act as a drive key. I would check by removing the sender unit/cable and seing if the gear can be rotated around the shaft. If it can be moved take the unit back to the reconditioners and ask for a warranty repair as the ball/ key has probably fallen out during assembly
Jan 05, 2013 | Cars & Trucks
The plastic gear inside that locks the brake handle into place of my Bugaboo Cameleon disintegrated. Where can I find the part?
If you contact www.bugaboo.com they will happily sell the complete break assembly to you. This is easy and quick to fit and should resolve your issue.
I hope this helps.
Aug 02, 2009 | Bugaboo Cameleon Jogger
Motor runs, collet doesn't turn
get a hot glue gun and go to your local hardware store and buy a piece of tubing to fit the collet shaft fill with hot glue and press it on the shaft.
Jun 19, 2009 | Dremel Variable - Speed Multipro Rotary...
Gear attached to moter is broken
This is how a got my gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Mar 26, 2009 | Office Equipment & Supplies
The lift extended to far down and will not come up. need diagram to show how gear shaft connects to raise platform
their should be a plastic plug on top of the cover, remove round plug and insert deep socket with extention and manually turn. this should free-up the worm screrw and allow the motor to work
Mar 25, 2009 | Harmar Mobility AL410 Universal Inside...
Dishwasher kenmore 665.
i will look into it.. may i know if u can find the part #.
Aug 08, 2008 | Dishwashers
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
242 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen II
Van Allen II
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
