Televison & Video Logo
Posted on Apr 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power even if I plug my DVD to power source
Anonymous
Level 3:
  • Master 517 Answers
  • Posted on Apr 17, 2011
Anonymous
Master
Level 3:
Answers
517
Questions
0
Helped
117237
Points
1424
Good day.
Follow this procedure for trouble shooting.
  1. Remove the cover of your DVD player.Loosening all screw.
  2. Check the input voltage of the power supply 220v/120v AC.If don't have input supply that comes from the ac cord,replace it.
  3. If you have a input voltage supply comes from the power cord.Check the output voltage of the power supply such as 5vdc and 12vdc.
  4. If the you don't have output voltage from the power supply.Check the fuse if busted,check open/change value of capacitor,check power transistor (regulator)if shorted and leak/bulging top capacitor of the power supply board.If you found any defective parts replace it.
  5. If you have output voltage comes from the power supply.The problem could be the main board,replace it.
  6. If you already done this procedure,test it by power ON the DVD player.
I hope this information will be helpful.Thank you and good luck.
My DVD play will not turn on
Try changing the power source and connect it.Make sure the power cable is completely plugged into the power source.
If still can't turn on,take it to a repair shop and have the power cable replaced.
Hope this helps.Thanks!
Mp95 wont turn on. The battery pack wont charge and player also wont turn on while power source is hooked directly up to dvd player without battery pack. Please help?!?!
The battery it is dead,even u plug the dvd player power in directly into the power source.Must have the battery inside and the must have some juiced left before for the dvd player to work.Tries websites like Partstore.com,Amazon.com,Ebay.com to buy a new battery or a compatible one.
2helpful
Dvd dvd door will not stay closed. tried turning off and on multiple times. just keeps popping open.
Reset your player. Press and hold the FF and RW buttons at the same time on the main unit itself for 5 secs. Afterwards, unplug the player from the power source and let it sit unplug for a minute. Plug it back in to the power source and turn it on.
If its still the same issue,I just want to inform you that your unit laready needs service for repair.
Sincerely yours,
Genius 101
1helpful
How to charge battery, is there a charger that we have lost or does it charge while on player & plugged in
The player charges, with or without playing a disc on it,
First step to charging your battery is having it plugged without playing it for a while.
There should be a light that comes on when you plug it to a power source.
When it is full, there also is another light that comes on to signify it is full.
You can also charge it while playing a DVD on it.
But if it does not charge when you plug it without playing a Disc on it, then there is a problem that need to be fixed on it.
test if the battery is charging.
  1. plug the player to a power source for some time,
  2. wait for some time for it to have charged very well,
  3. unplug it from the power source,
  4. test a disc on it to see if it will play.
if it does not play, then it means there is a problem.
which could be that the battery may be faulty.
All you have to do is to replace the battery and it will work perfectly fine again.
take care
My acer aspire e500 has no hard disk aactivity
Try to discinnect CD/DVD driver also when you power on main cor dont instantly power on case, wait 5 minutes and then try. Such kid of failureas are causer by power adaptor system. Also try bios reset put off battery and wait 5 minutes to reset CMOS also power cord must be unpluged. Unplug and plug power sources to mainboard. then turn on.
1helpful
Nosignal when i power it on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are trying to view the DVD on the Samsung TV, you need to firstly connect the DVD to the appropriate connection on the TV.
Once connected, with a Samsung TV, you need to press the SOURCE button on the TV remote control to view any external sources such as your DVD player.
The ‘NO SIGNAL’ message would indicate there is no signal, if you have not tuned your channels in, this may be the digital tuner you are viewing. Press the source button whilst a DVD is playing in the DVD and see if an image displays.
Phillip DVD Hard drive power failure
You should take firt a voltimeter and test for 5 and 12 volts at power input to de HD,(pluged to the wall) as some times is the power with has been fried...if so test diodes first and transformers then (unpluged from the wall...) if not ok and you do not know how to fix the power source take it to an electronic shop and they will perform a standard repair as it is only a power source......
1helpful
Tv won't turn on either manually or with remote
THE RCA TV WILL NOT COME ON ,BUT THERE IS A LITTLE HUMMING SOUND
2helpful
2answers
Supersonic FC2200 TV Power Cord Usage
need a power cord for FC2200 supersonic hdtv. where can i find one
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
