Mine did the sane thing. Since I had cassettes in at the time, I noticed that neither turned and I saw an "E" on each display. Figured the belts were broken or something. Unplugged unit and removed the cover. Both belts on each side were stretched out enough so that the wheels would not spin. Each side has 1 flat belt (like a rubber band) and another that is smaller , skinnier and perhaps circular in it's diametric shape (like an o-ring). A repair kit on E-Bay is $16.00 plus shipping and that's if you know how to replace them. A better bet is to go to your local Goodwill store and look at the electronics area. I found the exact deck there 8 years ago and it worked well. It cost me $9.99
SOURCE: where can i purchase belts
You only need to measure the diameter of each belt you need in MM. Then put the result into Google as "Cassette Drive Belt ??MM."
Belts are generally universal and not made by any one maker. You don't have to be precise in the MM also, a few either way will work. Make a note of how they fit before removing any.
