Dyson DC33 Bagged Upright Vacuum Logo
Posted on Apr 17, 2011
Right out of the box, the vaccuum has been making the grinding noise indicating that something is blocking the beater bar. There is nothing blocking the beater bar, but the clutch piece appears to drop lower than the indicator line for carpets when extended for normal carpet vaccuuming. The noise is happening intermittently on the carpet setting. Do we have to take it back to the store, or is there a fix for this problem?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1086
Points
I found the fix for the dc 33. Open up the cover to the beater bar. look at the cover. You will see many small triangles. Look very closely for a small rubber strip that runs along the edge where the triangles are. It is kinda hard to see. Once you find it remove it. Now on the vacuum itself there is another strip. This strip is very similar but a little longer. Remove that strip. No more **** noise whalla. The perfect Dyson!
What does a flashing light on the dc28 vaccuum mean
There are a few things a flashing light could mean. One is that the beater bar has something stuck on it. Or, it could be that the bag or canister is full. Then again, maybe something is stuck in one of the intakes. Be careful when checking the beater bars. Unplug the vacuum before touching them, you wouldn't want your hands getting injured or fingers broken:( Clear anything that is wrapped around the beater bars, hair, string, etc., and then check the hoses to make sure nothing is stuck in them. If you have suction, the interior is clear. If not, then check in there to make sure nothing is clogging it. Good luck and be careful:)
Dyson DC27 beater bar making noise
I'm sorry to hear you're having difficulty with your DC27's brush bar. If you haven't already been in touch with us, I'd encourage you to give our Helpline a call on 1-866-693-9766 (US), or 0800 298 0298 (UK), as we may be able to resolve this issue with some simple troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
My beater bar makes a noise and has a crack in the motor on the beater bar and is discolored--me thinks I need a new motor for the beater bar
Sounds like you're right. New motors are available at your nearest Aerus Electrolux store. They used to charge the same amount for selling the motor and letting the buyer install it, or for installing it in the shop. Worth checking in to.
http://www.aerushome.com/storelocator/
4helpful
2answers
He dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
2 year old machine...new noise in beater bar area
I have a dyson 17 animal and have a loud noise comming from the beater bar area.Also I don't think the hight adjuster is working properly.
1helpful
Power head on epic 6500 does not work, is there a belt?
This is a bot of a blind guess, I don't know the model. But most power head cleaners I have worked on use the suction of the vaccuum to spin a turbo fan in the head (like blowing a child's windmill). The head not spinning is usually because there's not enough **** to spin the turbo fan. Check for:
Gummed up brush bearings (dirt or damp) making the brush harder to turn than it should be.
Poor suction caused by a blocked or partially blocked pipe.
An obstruction that is tactchin the beater or the turbo fan.
Blocked filters on the cleaner, reducing the **** and thereby not providing enough vaccuum to spin the beater.
Dyson animal
Is the noise a loud screaming or a grinding/vibration? The screaming is an air flow problem and you'll want to check your hoses are clear and all the seals are tight. The grinding is an issue with the roller/belt/clutch/motor/housing. From what I'm reading, both problems are common on the Dyson animal.
2helpful
2answers
The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Vaccuum stopped running
Belt jumped off beater bar and jammed it! Disconnect belt, does imotor run. If yes, reconnect belt turning beater bar by hand to see if it is smooth. Carefully, reassemble and run it!
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
