Difficult call there as whirlpool has a strange manor especially with the larger units. I had a callout on a double door whirlpool unit once and the compressor wouldn't come on but i couldn't find anything wrong. Anyway, i decided to leave the fridge untl the next day giving it a chance to possibly come on. About 5 hours later the customer called and said unit running very well and no more problems. Basically leave on for a few hours and see. If no output then call a tech .The testing procedures need equipment and electrical info..
The humming noise is most likely from vibration, check to make sure the freezer is level.
If it is level look in the back lower area there is a compressor, black component about the size of a bowling ball, make sure nothing has fallen on it or touching it causing the noise.
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
If all is working fine otherwise ,check the fan in front of the condenser.It may just be the wear in the fan bearings.A replacement fan would be all thats needed to fix then.
Possibly has a restricted capillary tube. Possibly has a extremely dirty condenser coil. Possibly has a bad compressor which will run but has bad valves so it doesnt actually pump the refrigerant. If the condenser coil has a fan (unlikely) it may be dead and causing the unit to run much higher pressures than normal which could cause this. Only thing you really could do would be clean the condenser coil. Anything else would need to be repaired by an Refrigeration Mechanic.
