Stoves Premier 600GRa Gas Single Oven Logo
shaji antony Posted on Apr 16, 2011
Am using stove single gas oven. While working the oven, the spark light always getting tick tick sound, If am opening the cover, no sound ( sorry, my english very bad). I like my oven very much. How i can solve this problem thanks
4 Related Answers
Anonymous
  • 734 Answers
  • Posted on Dec 02, 2008
SOURCE: Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Anonymous
  • Posted on Dec 30, 2008
SOURCE: hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Anonymous
  • Posted on Oct 05, 2009
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Anonymous
  • 147 Answers
  • Posted on Dec 22, 2010
SOURCE: My stove is a General
THE SAFTEY VALVE IS NO GOOD OR YOU HAVE NO GAS TO THE RANGE
Burners will not light
check the igniter switch on back of stove might have gone bad. Also make sure your stove did not get unplugged by accident. no electricity no spark
1helpful
One or more igniters are trying to light burners that aren't turned on .One burner is on. The other post on this never got answered properly.
When you turn the burner dial, all igniters spark. Most brands work this way. The dial activates all igniters to spark but only opens the gas valve attached to that dial.
Do you mean that they continue to spark even when you are not trying to light the stove?
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
1helpful
2answers
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
OVEN WON'T LIGHT AND HEAT, NO GAS SMELL
Hi!!! check your oven spark module its inside the oven it looks like this pisture..The module provides the spark to all ignitors..Good luck..
1helpful
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
1helpful
How to light the pilot in my RV?
push in on the themostat when the oven is on piolt hold a lighter under the burner and presto also light the stove to get gas flowing first this can take up to fifteen min to light if it has been awile since lit
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
1helpful
Starter
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
1helpful
2answers
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
