During printig a paper half-way, the display panel showed (Power Off/On Fatal Error: 917). I have tried to check the back boards but to no avail. What does the code mean and any possible solutions?
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
917 relates to the transfer belt.
lift out the drums, and check the belt, it may be torn, ..
if not remove it and reload it, making sure the blue tabs lock right down securely...
your belt life may have expired...good luck
Probably your transfer belt is torn
A 917 error suggests a problem with your transfer belt
My error cheat sheet says (**** sensor) Transfer belt. Where is this sensor?
