Nokia 5800 XpressMusic Smartphone Logo
Posted on Apr 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mobile displays no memory card inserted when there is one
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Apr 16, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
14803
Points
217
May be memory card is not inserted properly, plug it out and insert it again. and switch off and then do on your phone.
if not working by doing above...
Then there may be memory card problem, or format of memory card not supported by phone...
Do a memory card format using your PC, format it with NTFS file system. and then insert it into your phone it may start working...
Thank You
4helpful
I PURCHASE 4GB MEMORY CARD AND INSERTED IN NOKIA 6303 CLASSIC MOBILE, FEW DAYS AFTER MEMORY CARD FAILED AND NOT ABLE TO OPEN, WHEN IAM TRYING TO OPEN IT DISPLAYS "MEMORY CARD NOT FORMATTED...
1. Insert the memory card in a card reader.
2. Connect it to a PC or a laptop.
3. Go to My Computer > Removable Disk
4. Right click on the Removable Disk icon and click on format.
5. This shall format your memory card.
6. Run an anti-virus scan on it in order to fix any possible bugs.
3helpful
Nokia6300 - SD card(512MB-Password protected not recognised)
If the particular mmc is not displaying in your phone and display other mmc it is not a password protected actually the mmc is damage.
2helpful
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
4helpful
2answers
Memory card is not working...
You should not use the memory card from other mobile to motorola. When you insert the memory card two folders will be created automatically (Sounds and images) You have to put the songs and images in the relevant folder, then only you can access. Otherwise it will display that you don't have files in the memory card.
Take a copy of all the songs and images to your pc.
Then follow these following steps
1. Format the memory card.
2. Insert the memory card to motorola
3. Transfer the files and folders to the folder(Automatically created folder)
4. Safely remove hardware
Now you can enjoy music.
Cheers...!
Mr.Maduraikaran.
Insert memory card for connecting as mass storage
Sorry, no solution here. My LG840G TracFone giving me similar problem. When I plug in the data cord the phone displays, "INSERT MEMORY CARD FOR USE AS MASS STORAGE." It's ALREADY inserted, for Pete's sake!!! What's up with THAT???
2answers
My nokia N99i China mobile recently developed a memory card fault
I removed the memory card and inserted another one, I then removed the memory card and inserted the original one, it doesn't display memory card in the file manager. and when i'm taking a picture it says "restore etc. " in my restore factory has a password . i don't know what is the password . can u help me .
1helpful
2answers
Meory card acces not allowed
I have samsung mobile sgh j700 my problem memery card on the click not open but format display indenti i am click format displayed error not format what i do
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
K 750i
switch off your mobile and then insert memory card
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
