Question about La Crosse Technology TX37UIT 915MHz Wireless Temperature Sensor
Lacrosse Technology WS952OU - display won't show outside temps and now after removing/replacing batteries numerous times, shows message OFL.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Having same problem. Replaced with good new batteries from 2 different brands and still no go.
Posted on Jul 08, 2017
2 Suggested Answers
SOURCE:
  • 1417 Answers
SOURCE: outside remote sensor, when i insert batteries,get
Hello.
The problem can be from two point of view.
1). from the battery capacity if not up to the voltage expected to be use.
2). And also if the battery sensor is not compatable with it.
However, what you need to do is to test run the system with another battery in other to be able to locate were the problem is from if from the battery or the the system it self.
you can also get back to me after the test.
Thanks.
Posted on Sep 12, 2011
BAR888A -Changed batteries house (1st) & outside unit(2nd.) Now inside unit not receiving signal. Only thing registering is inside temp. Outside unit is also showing temp.
Remove all batteries. Install batteries in outside unit and allow time for it to begin sending temperature. Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit could be defective.
Sep 25, 2018 | Measuring Tools & Sensors
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
Outside temp battery quit yesterday. replaced batteries inside and out. outside temp will not show. what to do?
  • Remove batteries from both units
  • Install batteries in outside unit. Allow time for it to initialize and begin transmitting data.
  • Install batteries in inside unit. You should see outside temperature displayed. If not, there may be a problem with the outside unit.
Mar 18, 2018 | Measuring Tools & Sensors
Outdoor temp doesn't show on my LaCrosse 8349
try changing channels on all sensors and the receiver.. You will have to go through a wait time as before. This worked for me last year, but mine eventually failed completely this year
Jun 14, 2017 | Measuring Tools & Sensors
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
Do you have to change batteries on clock inside house along with outside batteries to get correct outside temperature
My most consistent (best, repeatable) results with this process are to replace both sets of batteries, both in the clock and in the outside temperature sensing unit. Start by removing all batteries out of everything. Now replace the batteries in the outdoor unit, then (within 30 seconds) replace the clock batteries. The temp unit should begin communicating normally within 5 minutes (or less) and yes, you will have to reset the clock,
Nov 01, 2014 | Lacrosse La Crosse Technology Wt-5220u-it...
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
What does an OF symbol mean in the indoor temp window with no readings from the outside?
Based on a different, but similar, LaCrosse model (the WS-8611), it would appear to be an OverFlow indication, meaning that it's out of range. Here's a quote from that unit's manual:
SPECIFICATIONS:
Temperature measuring range:
Indoor : 14.2F to +139.8F with 0.2F resolution
(-9.9C to +59.9C with 0.1C resolution)
("OF.L" displayed if outside this range)
Outdoor : -39.8F to +139.8F with 0.2F resolution
(-39.9C to +59.9C with 0.1C resolution
It is likely that their convention remains the same across models, but I don't work for them, so I can't guarantee it.
Sep 25, 2014 | La Crosse LaCrosse Technology Weather...
Outside temperature sensor not working
You probably need to replace the batteries. Be sure to follow the LaCrosse instructions exactly to get your Weather Forecaster working properly again
Jun 30, 2013 | La Crosse Measuring Tools & Sensors
Outside Weather Not Displaying
Restart as if from new ie as if it is being taken out of the box
Jan 25, 2008 | La Crosse Technology WS-8001-UM Digital...
La Crosse Technology TX37UIT 915MHz Wireless Temperature Sensor Logo
3,873 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
