SOURCE: nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
SOURCE: nokia 5800 xpressmusic backlight not turning ON
Hi Friend,
As you have mentioned that you are not able to turn on,this may be due to the follow the reasons,
1.Kindly check the display,if there is a problem in the display you will face this kind of problems.So kindly change the display and check it out.
2.Try by doing a hard Reset as follows
a.Switch off the Mobile
b.Remove the simcard,battery and the memory card
c.Hold the Switch on/off button for 20 to 30 sec's
d.Now replace the sim card and the battery alone,switch on the mobile
e.After the mobile switches on now insert the memory card
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: Nokia 5800 xpressmusic looking for unlock code
default password is 12345.
if u forgot your password and want a reset goto this link.
Go to this site and do it all by yourselves ;-)
http://www.lur.nu/nokia_mastercode/security_code.php?IMEI=
SOURCE: My Nokia 5800 Xpressmusic has frozen on the "Nokia...
hi the only thing to do is to reset the phone to factory setting by pressing the green button the camera button and the on/off button simultaneously
