Mitsubishi WD65737 65" DLP TV Logo
Posted on Apr 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
Electro Med Services
Level 3:
  • Mitsubishi Master 6,694 Answers
  • Posted on Apr 16, 2011
Mitsubishi Master
Level 3:
Answers
6694
Questions
Helped
1871020
Points
21433
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
1helpful
Heard a loud pop and picture went out. When tv turned on their is still sound but no picture.
I would first remove the lamp and look to see it is intact and not shattered inside.
1helpful
I have a Mitsubishi 65inch tv, Model WD-60735. I heard a loud pop noise, like if something burst inside. Then the screen went black but I can still hear sound. Shortly after the sound went out. I can hear...
Check your lamp. This is a common problem in projections. Sometimes there is a lamp door and two screws holding it in. you can physically see if it is bad. itll be shattered or have rings aorund it. anything that doesnt look right. If your lamp is fine then you may have blown a fuse or diode or ic chip..theres really a lot to go wrong. I would then take it to a repair shop.
Please take the time to rate. Thanks:]
No picture. no sound
Bulb may have popped. Cheapest fix, unless your an electrician it the only thing to really try before replacing set.
Loud bang, then audio only from my tv
YES YOUR YSUS PANNEL HAS JUST POPPED CHECK OUT EBAY FOR REPLACEMENT,,
6871QYH053B
IS THE MODEL BOARD U REQUIRE,,
THERE WAS A GUY ON EBAY 64.99 AND 12£ POSTAGE AS LONG AS YOU STILL HAVE SOUND AND NO PICTURE,, YOUR PSU SHOULD BE FINE,,
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
3helpful
2answers
HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
