I have the same problem. All of a sudden there are plenty white dots all around the screen. As if 1/3 of the pixels are burnt. It cannot be the lamp because it is still as bright as before. It must be the internal screen or whatever. The "Troubleshooting" section of the user manual does not mention such thing.
SOURCE: My Acer projector started gaining tiny white spots
Hi level7,
When I saw your concern my first thought would be the lamp is needing replacement. But based on your reply you already tried replacing it but still has the same issue. If system is still in warranty I recommend contacting the manufacturer and let them diagnose and repair it completely. I suspected that it's dead or stuck pixels and the only cure for this one is either to be repaired by the manufacturer or find a replacement for it.
Hope it helps.
Thank you for using FixYa.
