KLH 13" TV Logo
Posted on Apr 15, 2011
I have a 13 inch KLH TV/DVD combo. I bought an original KLH digital controller so I can find the code, but it didn't come with the instruction manual for the codes. How do I find the code for the TV?
Gerald Lavergne
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Sep 03, 2011
Gerald Lavergne
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
4569
Points
30
I need a remote control for a sylvania 6513DG tv
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
I have a apex combo tv/dvd player i lose the remote. I bought a universal remaote. I got it to work the tv but cant get it to operate the dvd
Hello
With a universal remote control, we can't get allthe functions do work as its orginal one. You have to check other codes for Apex, described in its user manual. Check other codes, and see which one will do best to get most functions with the TV. OK.
Need code for klh tv for universal remote
OOOOh from which remote? brand and model please!!!
My tv wont turn on sometimes pauses then comes
what make is your tv u still got insurance on it
Remote won't detect TV
as it a learning feature if so perhaps it could learn from the original controller. i have had universal controllers in the past that are rubbish and certain makes/models can't be controlled...
1helpful
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Analog vs Digital
You will need to get a digital tv set top box for this set to receive digital broadcasts.
This information was brought to you by Google.
4helpful
Remote control
I used a GE Universal remote. The package has number 24921 and the instruction manual says it's a RM24912. Anyway, this model will control pretty much all aspects of this tv combo assuming we are talking about the KLH KDT133UY tv/dvd.
What you need to do is program the tv button on the remote to code 0029 which is a KONKA code. The real maker of KLH electronics. Then set the dvd/vcr button to code 0905. Now in order to access the tv menu, press the tv button then press the shift button which is the setup button. Then press the INFO button for menu. SHIFT, MENU, OK, and EXIT are printed with a black backgroung on the remote. Hince you need to press shift.
Took a while to figure it out, but here you go. Good Luck!
4helpful
7answers
Klh tv codes
Hi my name is Lawrence Harris and i need some codes
for klh universiral remote control.
Thank You....
Sep 21, 2007 • KLH 13" TV
Top KLH Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
