Jenn-Air JED8430 Electric Cooktop Logo
Posted on Apr 15, 2011
I have a Cooktop Jenn-Air Model JED8430. The cooktop glass is broken. Would it be possible to change only the glass? If so, where could I get an other one ?
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Apr 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
10249
Points
75
Yes, you can change just the glass. It is called the maintop assembly and usually starts at $275 and goes up. You will need to get the remaining 3 digits for your particular model in order to get the right glass. A good place to start looking would be: http://www.searspartsdirect.com/partsdirect/part-model/JED8430?pathTaken=modelSearch&prst=0&shdMod=JED8430
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
1helpful
Installing Jenn-Air cooktop, model jed8430
Hi, W/D here.
The plenum is the box the blower assembly attaches to. The blower pulls the cooking vapors down the plenum (well) and discharges through the duct.
Best regards, W/D
1helpful
Ookware should I buy for a Jenn Air
i would avoid cast iron or nickle pans as they are heavy and coarse. i would recomend a nice stainless set with aluminum bottoms
1helpful
Jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
4helpful
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
1helpful
Jenn-air JED8430 cooktop
Fairly difficult but doable for the mechanically inclined. They are all a little different - look underneath to uninstall the entire unit (turn off power first!). It is probably held in by a few screws. The glass is likely held by screws underneath as well. Hope this helps!
Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
My jenn air cooktop only gets warm and only has 110 volts?
how old is the cooktop? may have a broken or disconnected wire in it.
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
