That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Replacing the turntable motor.
The motor assembly is fixed to the base
of the oven usually with two screws and access i obtained by removing
the inspection plate directly beneath the motor. It is usally a plug
in synchronus motor that revolves at a few revs per minute but the
plastic cogs in the motors gear box fail and the motor assembly must
be replaced. They are fairly inexpensive and obtainable usually from
a domestic appliance repair shop.
If you feel confident,
disconnect it from the mains power, remove anything in the cavity and
turn it upside down if it is a tabletop model, a little more
complicated if it is built in!
Remove the inspection plate and
disconnect the motor. Remove the motor and go and get a new one. Re
fit it and put the microwave back in its position. Plug it back in,
with the turntable and plate. Put a cup of water on the plate inside
of the oven and heat for 20 seconds to check the plate goes
round.
Hope this helps.
