Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again.. or 2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge.
Regards,
polysandy
ERROR 1203 LEXMARKERROR 1200Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
Hope it will work for you take care all the best Pineworks
Hi there ERROR 1203 LEXMARKERROR 1200Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again.. or 2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Occurs when a cartridge is bad or misaligned. Try removing and reinserting cartridges, first. If still a problem, then replace cartridges. Hope this helps.
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
