There is a fuse and I think the fuse is the problem if you think your power supply is good
Buy a tri-crew drive ship on ebay $2
fix it by your self because you have no warranty (it is 6 years old)
open it up then replace the fuse
here is where the fuse should be http://i47.tinypic.com/2lbko7b.png
This will also help to open up the wii http://www.ifixit.com/Guide/Repair/Repairing-Nintendo-Wii-Drive-Board-Fuses/4029/1
Make sure to order the fuse with the screw driver too. It should cost you less than $10
If you don't want to replace the fuse, just use wire and solder the two solder pads for the fuse but this method is bad.
Please rate if this helped you.
This procedure must be followed for each additional Wii Remote added to your system.
hope this helps
