Try pushing the reset button on the top of the power head first. There is a protection system on Kenmore canisters that protect the belt from breaking, and if something was vacuumed up into the head, it will cause this reset switch to activate to protect the belt. On the top of the power head look for the a small red button, or a grey button that says overload protection switch, and push down on it.
If the power nozzle lights are coming on, and the machine is making noise, then this means that the belt may be off inside the head, however if you're not getting any power, and the head light is not coming on, then this is probably a bad hose on the unit.
I have written a detailed repair on how to replace the belt on the Kenmore canisters on Fixya, just follow the link below. The only difference on the one I helped repair and yours may be the that the screws are actually located on the bottom of the power nozzle rather then underneath of the headlight cover. The other steps will be the same, just unscrew the screws on the bottom of the power head.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Please let me know if this didn't fix it, and I'll help you walk through this further and help you diagnosis the power head further.
Thanks,
Chris J.
GoVacuum.com
My 4 year old pushed this button and now the vacuum is not working when I plug it in.
So then what? Does the motor need to be replaced? or replace the fuse? I've already replaced the male lead wire as it was frayed. I got the power head to work briefly then the rollerbrush started smoking--a string was bound up in the roller. I removed the burnt string but the motor doesn't work now.
i have the same problem but i also can not get the power head to even look at it i follow the instructions to remove but will not in able to look at what may be wrong what could be avoiding it to open ??
