SOURCE: I dont know how to replace the internal battery on a Korg M1
You should be able to remove the top cover off your keyboard and see the quarter-size battery mounted in a holder on one of the circuit boards.
I don't recall the exact location on this particular model, but once you've located it, all you have to do is slide it out from under the contact spring that holds it in place and slide a new one in.
You'll want to make the swap fairly quickly as some models can lose their memory settings if battery power is lost for a relatively short amount of time.
SOURCE: Hi, I have a korg
When my Korg D8 power is on working message is followed by int>? I cannot go beyond this message how to solve this problem? Can I change Internal harddrive?
SOURCE: hi i got the korg
Hi
I have the same problem here, just happened today. Can you update me on the status of your device and how you fixed it?
Thanks
