Klipsch Original Nokia Stereo Headset WH205 WH205 35mm AV Connector Logo
Posted on Apr 15, 2011
I am using nokia stereo WH-701, i am able to hear the music but i cannot use the controls, all of them, i'm using C7 nokia. i'm desperate how to make it work.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 06, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
424
Points
0
Headset board wering image
Gayan Jayampathi
Level 1:
New Friend:
  • Posted on Jul 27, 2012
Gayan Jayampathi
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
424
Points
I have a nokia wh 701 headset.It has a problam in av conector.please give me av conector diagram.
Anonymous
Level 1:
New Friend:
  • Posted on Jul 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
424
Points
I also have same problem,i want same solution.my cell is nokia 5235 and Nokia Stereo Headset WH-701
2answers
1helpful
How to change battery in nokia monster WH-930
There is no battery in this model headphone. Look for a broken wire. You'll need a continuity meter to test for open wires.
2answers
Is there a way to play my IPhone music on Hyundai Accent 2005 Stereo? It's annoying that I have to use a CD.
Play music through USB in the car - Windows Central Forums
forums.windowscentral.com/.../209188-play-music-through-usb-car.htm...
Dec 19, 2012 - 25 posts - ‎18 authors I own a Hyundai Sonata 2012 which has a USB port that worked perfectly for listening to music on my iPhone. ... and it SUCKS. i want to be able to charge my phone via USB while I listen to music. .... I even bought an ALPINE stereo head unit and tried that, as they supposedly work with NOKIA phones, but.
2answers
I cannot hear when i call, i can only hear when i put on the speaker. why?
you have just one choice to get it to ur provider or to send it to nokias if warranty still available.
1helpful
2answers
How to repai nokia wh 701 headset when only one earphone is working
HELLO SIR I HAVE NOKIA C7 MOBILE , BUT I AM FACING A PROBLEM SO PLEASE CAN U HELP ME, WHEN EVER I RECIVE A CALL I CANT HEAR THE VOICE OF A CALLER SO WHAT CHANGES NEED TO BE MADE IN MY MOBILE SO THAT...
Try turning your volume up all the way so you can hear the other person. The volume control should be somewhere on the sides. Or it may show up as a slider with a picture display indicating which way to increase or decrease the volume.
I am using a Nokia Stereo Headset WH-205 with my MacBook Pro. The sound is distorted. Is the WH-205 compatible with the MacBook Pro ? Just to find out my new WH-205 might be defective or if I am facing...
The nokia headset is setup to carry both sound audio to the ear buds and microphone audio to the device. It is not setup to be used in a regular headphone jack unfortunatly and that is why you will get distortion and possibly damage your nokia headset by using it in that manner.
I need unlock code for nokia c7 movistar spain locked
u can get the unlock code for your nokia c7 model from by using this link http://www.theunlockarena.com/
following instructions makes u easy to unlock your mobile
1 - Switch on your Nokia C7 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C7.
3 - Compose #pw+CODE+1#.
4 - The Nokia C7 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C7 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C7
Each Nokia C7 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C7 mobile phone using the form above.
Top Klipsch Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Klipsch Radio Communication Expert? Answer questions, earn points and help others
