Televison & Video Logo
Posted on Apr 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW CAN I HOOK THE Panasonic TH-42PX75U TO THE VGA OUTPUT ON MY COMPUTER?
martin-r
Level 2:
Novelist:
  • Expert 151 Answers
  • Posted on Apr 15, 2011
martin-r
Expert
Level 2:
Novelist:
Answers
151
Questions
0
Helped
31879
Points
435
If your computer has an HDMI socket, all you need is an HDMI cable. If not you need a VGA cable (the blue cable that usually connects a computer to it's monitor. One end goes into the socket on your TV marked VGA or PC. the other end goes into the monitor output on your computer. if you have a laptop, there will be a vga socket (usually blue inlay in the socket) on the side or back. you will then need to set up the second screen in Control panel, display settings. If using the VGA cable, you will need to run an audio cable from the speaker/headphone socket of your computer to your tv (there will be a 3.5mm jack near the VGA socket) or to your audio receiver.
Good luck.
Panasonic th-42px75u used as a computer monitor has terrible resolution
try connecting using a HDMI cable and after connecting,restart your pc so the windows sets the resolution to optical.
Our Panasonic 50" TH 42PX75U
well it sounds like something fried inside the tv. In my experience, this sounds like your y-sustain board went bad. it could be your video board also. considering todays value of the 50" panasonic plasma, it will be cheaper to replace it, unless you are willing to spend around $300 to get it fix at a shop.
good luck
How do i replace the backlight on a Panasonic TH-42px75u?
Plasma displays do not have backlights. The ionized gas (plasma) in the pixels is the light source, just like a tiny neon light. If your screen is dim or blank, check the high voltage supply that ionizes the gas.
My Panasonic TH-42PX75U 42 in. Plasma Television has a problem: No picture Sound OK
this looks like a defective sc board with or without buffers repaire cost about 400 dollars
2helpful
Panasonic TH-42PX75U Blue Screen
This could be a reception problem of the cable transmission or the cable box if used. Are you using cable or SAT box. Tv goes to blue screen if signal is weak automatically.
1helpful
SCREEN WENT BLANK, POWER ON INDICATOR LIGHT FLASHES 7 TIMES GOES OFF FOR A FEW SECONDS AND REPEATS.
SU OR SU BOARD BAD NEED REPLACED
TH-42PX75U PART:
Manufacturer Panasonic Part Number TXNSD1HNTU Description SD BOARD
Manufacturer Panasonic Part Number TXNSU1HNTU Description SU BOARD
2answers
Broken glass on tv
You can find the Front Glass for this model in the link below.
Panasonic TH-42PX75U Front Glass Replacement
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
