Whirlpool dehumidifier Mod AD70USS1 The diiagram shows two top cabinet disassmby "screws" item #5, 9742177 to be part of the assembly. How do you remove them? From the back, they look like nuts, definitely NOT screws from that angle. How do I get these out? Thanks F. Paul
SOURCE: Whirlpool DEHUMIDIFIER Model -
According to the Owner's Manual for your model, the fan will run continually, if the unit is set in continuous mode or if the unit is in defrost mode. Once the unit senses a rise in the humidity level, the compressor will start up again. Also, a dirty or clogged air filter will cause the fan to run more that it should.
Hope this helps you troubleshoot and solve the problem.
Hey friend, thank you for your post!
I understand that you would like to remove the cabinet within your Frigidaire dehumidifier. Typically, the cabinet is not accessible. If you need to access anything internally within your dehumidifier I would suggest seeking assistance from a professional. Best regards! -Matt
