Make sure your scanner is working properly and the software has been already installed to the server or computer to access the scanner. this steps can help you to operate the scanner.1. connect the scanner to your PC, mostly scanner now is using USB cable 2. and then turn ON your scanner, place your material to be scanned like you were using photo copier 3.press the scan button to acquire the image 4. then preview the scan, the scanner software should display a preview on your computer screen 5. and now select the scan area in the scanner software 6.next set other options for example set the the color or the resolution of the document 7. then scan the image and save it into your disk make as your new folder. after you save you can now send this document.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
