Cars & Trucks Logo
Anonymous Posted on Apr 14, 2011
Only the left side of the drivers side seat moves when you try to adjust the seat forward or backward
  • Anonymous Apr 15, 2011
    the problem is with the power seat. The cbble turns on the left side but just seems to spin on the right side
Terry Reimink
Level 3:
  • Chrysler Master 458 Answers
  • Posted on Apr 14, 2011
Terry Reimink
Chrysler Master
Level 3:
Answers
458
Questions
0
Helped
116778
Points
1367
You don't idicate whether it's a power or manual seat. Assuming it's a manual seat there is a link between the rails under the seat. It can become disconnected preventing the right rail lock from unlocking.
  • Terry Reimink
    Terry Reimink Apr 15, 2011
    Obviously something in the right drive or driven mechanism is slipping. The problem is going to be difficult to identify without being able to look at it .
Power driver seat will not fully move forward or backward.
make sure nothing is lodged under the tracks this is common things get thrown under the seat and stops them in the track
1helpful
What could cause my drivers side power seat to stop moving forward and backward?
sounds like you might have a switch problem if the memory for seat position works ok. If you have a multimeter that checks for continuity then you could start there at the switch but you would also need a wiring diagram for the seats
Drivers side front seat will only move forward and backward on left side but wont on right side of seat
there is a cross over wire under the seat that runs the other side.It may have become diconnected.If that is not the problem you can check the owners manual for a fuse
1998 Volve S70. The abs light and the tracs off light stay on all the time. any idea why? the drivers seat automatic button will move the seat backward but not forward. All the memory buttons work and it...
On ABS light most common problem is ABS control module , they failing left and right.
As for the seat adjustment , sound like you need a new seat switch.
2helpful
One side of driver seat does not move smoothly or at all.
Unfortunately you need a new seat track assembly. I'm an infiniti tech and have replaced MANY of these tracks.
1helpful
I just purchased a 2007 jeep liberty sport
I have a 2005 Jeep Liberty and the smae lever that tilts the seat also moves it forward and back. Press forward or back on the switch. Also check for blown fuse or a loose wiring connector under the drivers seat. Good luck, Techjoel
21helpful
3answers
Driver's seat unable to move forward or backward
There are plastic gears connecting the track to the seat assembly. Whne one of these strip the seat will only work or move to one side. Infiniti does not sell a simple fix. You are looking at buying an entire seat assembly complete with the module for all the electronics. It will be at a cost of around $950 - $1000. Once that is in, Infiniti must program the seat to the brain of the car, only then can you reset your memory settings.
2answers
Power Seat on Drivers side want go forward or backwards. It works in the other positions but now forward or backwards.
Good day;
What year is you car? Does the other controls work for the seat? and just to clarify the seat won't go forward of back?
Cheers
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
