1999 Oldsmobile Intrigue Logo
Posted on Aug 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
99 oldsmobile intrigue
The a/c starts blowing cold then it starts showing outside temp as cold, so it automatically starts blowing hot air. I know there is an ambient temperature sensor, but is there also a sun sensor?
  • Anonymous Mar 17, 2014
    ambient air temp sensor 98 blazr
Carlos Rojas
Level 2:
  • Expert 119 Answers
  • Posted on Aug 08, 2008
Carlos Rojas
Expert
Level 2:
Answers
119
Questions
0
Helped
79198
Points
390
The ambient temperature sensor going bad causes this exact problem. I've replaced many of them because when they show outside temp as being below 60 degrees, the A/C control module will shut the compressor off.
1helpful
Ac trouble shooting for a 2002 olds intrigue I have a 02 olds intrigue 3.5 LTE engine My ac compressor constantly runs it has pressure in line but not blowing cold air and help would be appreciated
Where the A/C hoses go into the fire wall , are there hot , cold ? Low on refrigerant . Not blowing cold air , is there air blowing out of the center vents ?
I have a 1998 Oldsmobile Bravada with automatic climate control that blows cold air in the winter and hot in the summer. The thermostat is working fine and it doesn't need flushed. There are no le
It sounds like the system is fried. Based on the description, it is just pulling in the outside air and not doing anything to heat or cool the flow. Unfortunately, this is a job for your preferred mechanic.
1helpful
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
1helpful
My 2002 oldsmobile intrigue was overheating so i bought a thermostat and waterpump and placed it in, now the needle will go way up to hot and then back down to middle again, and it will keep doing this,...
You have air in the cooling system. With the engine cold, remove the radiator cap (or overflow bottle cap if no radiator cap) and let the engine get to operating temp. Add coolant if it is low. There is no way to guess which of the 3000 codes your car has set without scanning it for codes.
1helpful
2answers
WHen we use the auto car starter, it blows cold air, and a lot of it. Its nearing the winter here in New England and I need to know how to set up the starter to blow warm air. Any ideas?
Start the vehcle and let it warm up then set all the controls to heater? Then turn off the car. Use the remote start to start the vehicle and check the controls are still set to heat mode.
1helpful
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
A/c on 99 oldsmobile intirgue blows heater hot on drivers side
The Intrigue has dual temp settings make sure the temp knob on the pass side is turned to cold
A/c blowing hot on one side and cold on other
Bad servo ,you have to go under dash to replade.
My 2000 olds intrigue blower stopped working
Most probable worn out blower motor sometimes you can jar or bump motor and it will work some.
99 Olds Intrigue outside temp stuck at 33°
Needs new ambient air sensor. Autozone has them. They go on front of vehicle near radiator. Easy fix.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
