Did you turn "ON" the Main power switch "ON"? Also, you have to press the power switch "ON" that is on the side of the control panel.
It could be an issue with the power supply unit as you get nothing light up on the machine
i would have it checked by a certified technician do not take panels off or try to fix this issue ytour self. you could check the sub switch this is located on the right side of the control panel also check to see if the front door contact switch is making correctly
