SOURCE: my message indicator on my
are you sure!
you are missing something!!!..........................make sure that you have enough memory on the phone(some phone do share the memory with phone book,message,and vertually everything in the phone programmes)....
even when you browse on the phone memory is used up for saved pages,cach,cookies and others(clear all this field)
clear all phone numbers on the phone that you do not need: but then keep a written log of all numbers too.
for the message part too clear all outgoing,report,templates(those you do not need),sent or draft folders cause this also take up space.
when you are through switch the phone off and put it on again.
this should solve the problem.
let me know the outcome.
good luck
SOURCE: Message indicator does not flash
memory may be full or off
go to page 26 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
SOURCE: flashing message indicator light is on but there is no message
from operators dss hit mw key then the ext you are trying to clear
SOURCE: message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
This should resolve the blinking light.
