Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
Posted on Apr 14, 2011
I have a frigidare stove model GLEF378ASE the oven will not turn off unpluged it to reset and pluge it back in and the ovn started heat again
5 Related Answers
Anonymous
  • 76 Answers
  • Posted on Feb 06, 2007
SOURCE: at a loss
gluehead Most likely it is a problem with the power supply. It suppose to come two hot (120V) lines to your range and looks like one of them is missing. I would reccomend you to call an electrician to check both circuit breakers and the power from the wall outlet. Gendos...post back
Ken-Mo
  • 14 Answers
  • Posted on Dec 22, 2007
SOURCE: F1 - oven will not turn on
You can try turning the power off for a couple minutes then back on but this is typically caused by a stuck key or a faulty control board. Either way you're looking at needing a new control board.
Hope this helps.
Anonymous
  • 7 Answers
  • Posted on Feb 09, 2008
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Anonymous
  • 76 Answers
  • Posted on Jan 01, 2009
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Anonymous
  • 126 Answers
  • Posted on Jan 02, 2009
SOURCE: stove stays on and 30 min. later it starts beeping and F1 code
An F1 error code indicates a faulty keypad and /or ERC electronic control.
My "Probe" keeps beeping. I tried cancelling...no help. Tried heating oven at 400 degrees as suggested by one person (to take out the humidity....)for 15 mins. Helps for awhile but then starts beeping...
The top oven the stove will lift up,with effort,and fold back,unplug first,and see if it needs cleaning and the sensors are in there I think,clean them,try to unplug it to reset,see if that helps.
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
[email protected]
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
2helpful
7answers
F9 error
hi there,
can you tell me the model # on your stove please?
F1 and F2
depends on the brand, most of the time its an erc (electronic range control) this can be replaced. find a appliance store near you, give them the model and ask for the price and availability of an erc. If satisfied call a tech. If a tech installs it you have a warranty... get the picture?
Hope this helps.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
