That would depend on the unnamed receiver.
Most receivers have standard analog stereo outputs labeled Tape Out or something similar. You can use them as sources for stereo analog material but their outputs are not variable or under any receiver sound controls so the Bose volume will need to be adjusted. If using a Tape Output, do not select the output for listening on the receiver. THAT would disconnect the other source you're listening to.
If your receiver has a Pre-Out for the desired channels, they ARE under internal sound controls so you could set and forget the Bose volume.
Hi again,
The problem that I have is that, the Bose System is connected to the TV and when I watch movies it sounds great and I also have a Mini Disc Player connected to the Bose controller, but I can't get no highs.
I wanted to know if I connect the way you are sugesting, will I be able to control the Treble and Bass through the Receiver?
You still haven't described the non-Bose receiver.
In general, it is best for your ears to have the audio from every source go directly to the best audio electronics; and best for your eyes to have the best video go directly from every source to the TV. THAT is one reason they have separate paths and cabling for both media from any given A/V source.
Bass and treble controls are generally placed electrically just before an amplifier stage in any product, especially so they DON'T affect tape recordings or downstream products which migh tuse the Line Level audio output; and they will NOT make up for severe deficiencies in the source audio, no matter where you apply them. You should ponder WHY the MD has "no highs".
You could have started with that piece of information.
Line Level or digital optical signals between the new receiver and the Bose will not harm anything and are, in fact, the only ways to feed it any audio. Neither one will give your new receiver local control of volume through the Cinemate.
Buying a new (presumably multichannel and digital) receiver without its own speakers to drive directly won't accomplish much for the sound or the Bose Cinemate other than to add the (presumed) FM and any other audio sources it uses to the mix. The Cinemate is for users who don't want the complexity of an A/V receiver and only want improved TV sound. In time, if you flesh out the new system, the Cinemate will become a limitation and will be redundant.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
I didn't buy the Receiver yet.
I went to Best Buy and they told me that was impossible to have the Bose Cinemate connected to a Receiver, they said it would blow up the Bose System, that's why I want to make sure if it really a Receiver can control the highs and bass of the Bose
