Panasonic PT-L785U Multimedia Projector Logo
Posted on Apr 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Projector posted error, "replace bulb" Projector
Anonymous
Level 2:
Sniper:
  • Expert 59 Answers
  • Posted on Apr 18, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
59
Questions
0
Helped
65743
Points
127
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Testimonial: "This is great news! Unfortunately I have already purchased a new lamp. It's probably good to have a spare on hand."
The Temperature light comes on after replacing bulb.
I am experiencing the exact same problem. hope someone comes on worn a solution. projector worked fine before replacement - all fans have been cleaned and are working properly. ..
2answers
Compaq MP2800 DLP Projector
If the projector is not getting a source it might go on standby maybe check where you plug it in.
Projectors require quite a bit of power and should be on a single loop/outlet not hooked up to a powerbar with more things on it.
Hope that helped.
Projector suddenly went unresponsive
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
2answers
I have a Benq w710st DLP projector and when i turn the power on after a minute it turns off. The power button turns off and both the lamp and temp lights turn red. How do I fix this and can I do it my
Like a previous post I too had the same issue with my Benq MW516 - after a 15 minutes working the light would turn off and the TEMP and LAMP lights come on red and would not turn off until the unit was turned off. I found the problem was a very dusty cooling fan for the light bulb and after using compressed air (do NOT let any fan spin up - this can damage the fan, hold it and rotate slowly after unplugging it from the logic board first). Once I dusted out the entire projector it is back to running just fine.
XL-2100U lamp cycles on and off
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
1helpful
C20x lamp error
This is due to thermistor problem. Near to the lamp one thermistor will be there please check connectivity. if it is failed please change the same.
Regards,
prakasam
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
