Question about MTX Car Audio & Video
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
    Scholar:
  • 111 Answers
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
Posted on Apr 14, 2011
6ya staff
SOURCE:
Can i hook up my MTX electronic crossover rt x01a to myvhome reciever
yes you can. you need a 12v power supply for you home. Purchase a 12v 5a supply and set it up like you would in a car.
Nov 10, 2013 | Car Audio & Video
Tryin to hook up radio i have to run a wire to the ignition fuse just dont know where it is for chevrolet silverado 1500 ext cab 2wh drive sc1 model
To hook up a radio you should actually locate the Acc. wire that comes off the ignition switch. There must be a wire or plug in the area where the radio fits and this should supply current when the key is selected to Acc and beyond. Connecting the radio anywhere else could damage computer circuits or other electronic components.
Jun 23, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
MTX 81000D amp doesnt work
Have you checked to make sure your sub is wired correctly to the amplifier?
May 30, 2010 | MTX Thunder 81000D Car Audio Amplifier
I have a 2002 olds alero and im tryin 2 hook my
Ok to start you need to go to this website and you will have to get the factory adapter for your radio so it can be modified.
.http://www.installer.com/cars/by_car.php?carid=4267 and also check this site this wiring diagram will help.
http://www.modifiedlife.com/2002-oldsmobile-alero-car-radio-stereo-audio-wiring-diagram/
Apr 16, 2010 | Car Audio & Video
I'm planning on installing a system in my pick-up and I was hoping I could get a little assistance. I was planning on using a pair of 5'' McIntosh ms486 coaxial speakers (120w max 4 ohm)in the front doors...
First of all use the larger output amp to power the sub. You can tell if its free-to-air if in the middle of the magnet there is a hole for "air" to flow freely. The advantage of free to air is they dont require much of an enclosure or next to none so you can mount it on a single piece of mdf wood and use the cab in the truck as an enclouse itself. I would bridge the amp for the sub to mono but be careful to tune so you dont "distort". Secondly the amp for the mid's shouldn't be bridged any maybe you could run the front and rear speakers off the same amp.. I would get an amp for rear and front speakers each and one for the sub. Your ouput rca's should goto the cross-over first then to the amp (sub) - then wired to your sub (mono) which is bridged. Ensure to tune your cross-over to lowest frequency for sub. Its easy to bridge an amp if its 4 channel.. looking at the speaker terminals it will look like ( + - + -) use the two outer most terminals to bridge to mono.
Sep 13, 2009 | Sony Car Audio & Video
Dont know how to set my crossover! mtx rt-x03a
This unit had a couple unique features: a center channel (summed) output and a differential output (right channel is subtracted from the left). Once you figured out you lows, mids, and highs. Center and rear. I recommend buying a cd to test out your sounds like your high, mids, and lows
Mar 06, 2009 | Car Audio & Video
Mtx audio jh202 amp
my amp is blowing fuses?? any hints?
Feb 03, 2009 | MTX JackHammer JH202 Car Audio Amplifier
MTX 4501 Mono Amp - no output
It sounds like you have a defective switch or a broken solder connection. If the amp is new, return it for repair/replacement. Don't break the warranty seal if it has a warranty.
Apr 03, 2008 | Car Audio & Video
Help putting code in
hello i have 2 audiofinics adf-272 i dont know what kind of amp to hook up with it which one do u think is best for them a mtx 4051 500 watt class d mono block or a mtx 801d 800 watts
Jan 27, 2008 | Car Audio & Video
Car Audio & Video Logo
533 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Philip Armitage
Pierre Laplante
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
