The problem is from the sound chip/IC of your TV. The sound chip is failing/defective and it is giving a sign that it needs to be replaced. It's getting worse that is why it takes up to days..........
The sound chip/ic of your TV needs to be replaced for the sound to remain permanent.
But before that, connect the TV to a DVD player and observe if there is going to be sound. If there is no sound on the TV using a DVD player, or if problem persist, then it means the Sound ic/chip really needs replacement.
Replacing the sound chip requires skill, so I would suggest you allow a repairman help you out. It won't cost you much fixing this problem.
Good luck.
