From your description it sounds like the bearings on the armature seizing up . Mainly the bearing on the bottom towards the pad. I see it a lot . It'll seem ok when turned on but under a load it can stop , slow down , smoke ....I'd start by checking the bearings. If it was the cord power would cut in and out completely. It doesn't have a variable speed switch or any speed sensors on that model. .if you have any questions feel free to ask and give as much detail as possible plz.
SOURCE: no sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
SOURCE: my delta 31-250 sander dc drive motor will not
Did the DC drive give you a fault code? It may have tripped on a current over load. Needs to be set to handle load.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: 3725Bosch 5" random orbit sander, loss of power!!
The 3725 had an overlap winding problem in the armature allowing no full power under load, I replaced mine three times before getting a good one, best 5" on the market tho.
SOURCE: My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
