Align the timing marks:
Here are the Timing Procedures from the service manual:
Click Here
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: Timing marks on 1999 Ford Ranger 2.5L.
Rotate the engine so that No. 1 cylinder is at TDC on the
compression stroke. Check that the timing marks are aligned on the
camshaft and crankshaft pulleys. An access plug is provided in the cam
belt cover so that the camshaft timing can be checked without removal
of the cover or any other parts. Set the crankshaft to TDC by aligning
the timing mark on the crank pulley with the TDC mark on the belt
cover. Look through the access hole in the belt cover to make sure that
the timing mark on the cam drive sprocket is lined up with the pointer
on the inner belt cover.
To install:
The spring cannot be used to set belt tension; a wrench must be used on the tensioner assembly.
SOURCE: need timing marks ford ranger
The timing marks are on your timing belt cover. There is a little circle on the bottom right of the cover near the harmonic balancer that you can pop out to see if your distributor accesory gear is in the correct position. The camshaft has a triangle on the inside of the gear that you can line up with this accesory gear. The bottom of the timing belt cover has your timing tick marks and you may have to clean off this rectangular piece that is sticking out on the cover to see the marks. A good timing gun and remembering where the number 1 cylinder on your distributor is a good start to timing your motor. Refer to a Haynes Manual and it will give you a good guide line on how to time your motor with TDC. I hope you have good luck with this!
SOURCE: what do the timing belt marks line up on a 94 ford
My apologies for the delayed response. I am going back to answer unanswered questions.
CLICK on the following LINK. It has the Timing Belt & Mark(s) Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my sincerest apologies...
Thanks!
http://www.2carpros.com/car_repair_information/year/1994/make/ford/model/ranger/1994_ford_ranger_timing_belt_diagram_marks.htm
SOURCE: I need the timing marks for a 1999 ford escort ZX2
NOTE: Make sure the correct (second) notch in the pulley is indexed to the lower cylinder block (6010).
Position the crankshaft (6303) just prior to top dead center. Install the Camshaft Alignment Timing Tool on the back of the camshafts.
2.Remove the bolt and install the top dead center timing peg
3 Rotate the crankshaft clockwise against the peg.
NOTE: Installation of the alignment tool into the exhaust camshaft (6250) may require the camshaft to be rotated clockwise.
Using a 6 mm Allen wrench, adjust the timing belt tensioner until the index marks are aligned. Tighten the bolt
Tighten the bolt on the intake camshaft sprocket.
Tighten the bolt on the exhaust camshaft sprocket in three steps.
Install the VCT oil plug.
Position the crankshaft just prior to top dead center.
